Hi
i wanted to make a low pass filter to filter out noise from a power supply, initially my filter was working fine without getting hot,
but while i was connecting and disconnecting the low pass filter so i can test it's performance, my ferrite choke got hot and the
coil coating melted...
the ferrite choke was taken from an old device and probably it wasn't suitable for the current i wanted to pass ~2.5A, the wire
appeared to be less than 0.4mm.
now i did my own ferrite choke using 0.5mm tranformer wire on a Feroxcube TN19/11/10-3C90 ferrite bead the inductance is 23mH,
the capacitance of my filter is 4500uF and the corner frequency is 15Hz, i want to ask what value capacitor i should add so the surge
and spikes can be absorbed before the ferrite choke gets burned again?
thank you.
thank you.
