external interrupt frequency counter pic
neelam29
hi m using this program to make a frequency counter using pic16f628a and external interrupt is on pin rb0 . method m using is measuring time betwenn two rising pulses. one the rising edge comes i start the timer and on another i stop it .and then calculate the frequency.code is as shown below.
m not getting the correct timer values.
;		INTERRUPT SERVICE ROUTINE
OVFL_ISR
		movwf   TEMP              ;Store the value of w temporarily
		btfss	INTCON, INTF		;check if it's a external interrupt or not!
			retfie			;else check other interuppt or return
		bcf		INTCON, INTF
		MOVLW	B'00000001'
		XORWF	T1CON, F
		BTFSC	T1CON, TMR1ON
			RETFIE
		MOVF	TMR1H, W
		MOVWF	TIMER1_HIGH
		MOVF	TMR1L, W
		MOVWF	TIMER1_LOW
		CLRF	TMR1H
		CLRF	TMR1L
		movfw   TEMP
		retfie
please let me know is my code correct?
Your ISR has got a number of flaws.
When an interrupt comes along, you don't know what the processor may be doing at that point. It may be about to store W somewhere and so you need to save W (as you do - but don't always restore it.). It may be about to test a flag and so you need to save the STATUS register.
This is done like so,
interrupt
                movwf   int_work
                swapf   STATUS,W
                movwf   int_status
                clrf    STATUS;  ensure were in bank 0
     ; other ISR stuff
exit_isr
                swapf   int_status,W
                movwf   STATUS
                swapf   int_work,F;	swap to file
                swapf   int_work,W;	swap to work
                retfie
Because of this, you can't use retfie in the middle of your ISR you have to use goto exit_isr.
The above maybe causing your program to crash. Correct these errors and see what happens.
I don't understand what you are trying to do with Timer1. Your code for Timer2 should work fine except you should clear TMR1L before TMR1H.
HTH
P.S. the variables int_status and int_work should be in the common ram area I.E. between 0x70 and 0x7f.
And, for the more experienced out there, I know that strictly speaking, only status needs to be common.
Re: Frequency Counter Project.
PIC Coder said:
Hi Neelam,
Can you please send me full project for frequency counter.
Bye
Try searching on google, MicroChip have a very old application note for a 50MHz frequency counter, and there's an updated version, originally by Weeder Technology.
My understanding is that only int_work need to be in the common as we must restore W last. Int_status can be situated in Bank0.
You are of course correct. The correct way would be,
                movwf   int_work
                swapf   STATUS,W
                bcf     STATUS,RP0
                bcf     STATUS,RP1
                movwf   int_status ;  this can now be in bank 0
Note to self, must remember to engage brain before moving fingers.
