Ethernet with micro controllers
Hesam Kamalan
Hi there,
I have one micro controller board with serial interface and i want to expand it with Ethernet micro controller and eliminate the serial port. since i have not enough knowledge about Ethernet and working with it, is it comfortable?
do Ethernrt micro controllers have OS? do Ethernrt micro controllers support TCP protocol?
Google for this one. Realtek has the chips you will need. You can pull them off $11 ethernet cards as well. You will have to write your own UDP stack though, but google I am sure will find you the code as well.
So find an old realtek ethernet card and google for microcontroller and ethernet and you will find projects out there.
That is a pretty broad question. perhaps a better approach is to use a complete ethernet module like digi connect or lantronix xport. more expensive but definitely easier to start with.
