Safety(Salute)
I ask you if you had an idea on an electronic circuit which detects the passage of the current alternative of the mains voltage by the zero. Or an assembly(editing) which allows me to measure the phase shift between tension and current of sector.
My realization is based on a peak 16f877 which receives both signals of current and tension and calculates the cosphi between both after he(she,it) it commende the opening and closure(lock) of the battery(drum kit) of condenser is not directly my has fault one the other card(map) which contain relays
Thank you
Thank you
