To understand better you have to realize what the first stage of an SSR actually is, it's nothing more than a optocoupler (for electrical isolation) that triggers the high voltage SCR's. So consider the input to an SSR to be nothing more than an LED. It won't start conducting until there's 3volts, it won't operate the high side until it reaches 5ma of current and will not tolerate a differential voltage over 32 volts or a current of more than 25ma. I say differential voltage only because these devices can be run on 50 volts DC or higher as long as the differential voltage was never more than 32 volts, consider the case of running it off a resistor on a 100 volt supply where the resistor is valued to drops 5 volts.Does this mean that the higher the input voltage is, the lower the control current?
It's not usually called zero voltage switching because obviously voltage has to be present on the switching side to function, it's refereed to as a zero crossing SSR. The bulk of all SSRs I've ever seen are all direct to LED I've never run across any with internal resistors, but perhaps you run across them in situations where they're designed as drop in relay replacements. The use of a transistor doesn't add much protection, if the isolation voltage of an SSR is surpassed to failure it will blow through most transistors like a rocket train, it does however offload the current required from the PIC to trigger the SSR as although I/O lines have current limits the entire port has a limit as well as there being a limit for the entire chip.dr peppers said:An SSR can be better way of switching, esp if the SSR has zero voltage switching, there are various types, all the ones I've seen have been 24vdc input, but you can get 12v, 5v and direct to led versions, if you can get a 5v input and the current is less than around 20mA (depending on the pic you use) then you'll be able to connect it directly to the pic (allthough using a transistor is reccomended for protection).
