It's not practical to try to add a mechanism to use the kicker as a starter. It would require a large device to handle the high torque required and to apply that torque rapidly. Think about the large force needed to operate the kicker. It's your weight times the length of the kick arm, probably more than 200 ft-lbs of torque.
If you can access the crankshaft it might be possible by using a starter from another motorcycle or lawn mower starter. The starter also has to have an over-run clutch to disengage the starter when the motor starts.
