I need some expert circuit advice. I am building an electric car. I will be using a Chevette. I have scrounged a GE 9.9kw motor and an ancient SCR drive that was in a forklift.
The SCR drive is of unknown origin from an old Clark forklift. From what I have been able to research, it is probably some form of Jones chopper. It has two large SCR's, a smaller SCR, a transformer, two large capacitors and other bits and pieces. The one important piece of the drive that I can't figure out is the epoxied electronic control module. I went to the local Clark dealer, but they can't help without knowing the model number of the forklift.
I was able to figure out the chopper part of the circuit though, and was able to test it with a small dc motor with 12 volts going into the chopper circuit. I found in this configuration, all I needed to do was to take the gate of the largest SCR and touch it's anode, and the motor would run. Take it off, the motor would stop.
So I had the idea I could build my own PWM circuit to drive the gate, thus making my own drive. I first built this circuit(low side version)
http://www.solorb.com/elect/solarcirc/pwm2/index.html
and it worked great by itself with the small test motor.
I then tried to mate this PWM circuit to my forklift drive. Here is what I did.
I first hooked the little transformer driving the primary and hooking the secondary to the gate. This pulled the drive signal to nothing when I hooked it to the gate. I measured the current of the gate when it is shorted to the anode, and it's about 50ma. I then hooked it in the configuration shown in the above diagram. The motor will run in this configuration, but will stop at either end of the speed control travel, and has very limited and unstable speed control in the middle.
I was wiring it this way according to a diagram I saw driving a Jones chopper. I assumed I needed the transformer for isolation. I will be running the PWM circuit on 12 volts, and the traction motor will probably have anywhere from 48 to 96 volts, depending on the top speed of the car. I am suspicious of the transformer not being correct. Do you think I could wind my own? Or have a source for one that would work correctly? I do need it don't I?
I have a 2 year electronics degree, but that was 20 years ago, and as you can see, I know enough to get myself in trouble. If you guys can offer any suggestions(besides spending around $1000 for a controller) I would be grateful.
Dave F
Dave F
