EEPROM emulation using Flash?
prabs1976
I'm looking for a design document on implementing Emulated EEPROM , any links ,tutorials or sample code would be of great help.
download PICC trial and there is EX_SLAVE.C that simulates 24LC01 eeprom.
but generally what you need to do is enable i2c and for i2c interrupt setup something like this
// put some config for your pic
// set this procedure as i2c interrupt
void i2c_interupt ()
  BYTE inc, state;
  state = i2c_isr_state();
  if(state < 0x80){ // master sending data
    inc = i2c_read();
    if(state == 1) address = inc;
    if(state == 2) buffer[address] = inc;
  if(state == 0x80){ //master requesting data
    i2c_write(buffer[address]);
void main(){
  //enable i2c interrupt
 while(1) {}
We need the manufacturer and device first. Yes, Microchip does provide Flash to EEPROM implementation. And it all depends on the device. If using flashed based PIC that does not have EEPROM, there are 2 types. Type 1 lets you write to flash at run-time and lets you write to individual random access bytes. Type 2 lets you write to flash at run-time but you must first erase a huge chunk of flash first, and then write to flash. Since a huge chunk is erases this of course raises the flag of "must I first save the chunk". That would be a yes if you want to keep that data and you must be all powerfull enough to know what chunks to access else you will suicide your own code at run-time.
