*Edit, OOPS!* can i replace this transistor?
daviddoria
update....
i built this i believe correctly just minus the transistor mentioned below.... and both of the IR LEDs burned up in like 5 seconds.
what the heck?
why would this happen!?
the only other thing i didn't mention is that there was a wire running to the 555 and it wasn't labeled, so i ran it to pin 7, as it was the only one missing. this was ok right?
** Original message **
http://www.bandtank.com/~calculusap/jammer.gif
is there anyway i can take out the BC557?
this is a self explanitor IR jammer circuit, just a toy, but i dont want to go buy this transistor. can i replace it with anything?
thanks
david
kinjalgp
Active Member
BC557 is used here as power switch. You can directly connect an LED to the output of 555 through a resistor without any performance loss because 555 can source as much as 200mA of current which is sufficient to drive 2 IR LEDs.
There is no other replacable device for a transistor except old vacuum tubes :lol: . Why you don't want to buy it? It hardly cost anything. Over here in my country BC557 is available for 0.02 US $
daviddoria
haha i dont mind the $.02, i mind the hour drive to the store. hehe
so i'm gona try this without the transistor and get back to you with the results.
thanks again
david
bogdanfirst
well, i dont see the much use of the transistor since the 555 can suply 200mA.....
but you can use any type of transistor for it, it is quite general purpose, 100mA, 45V, 500mW, hFE>110, .
i suggest some replacements, bc182, 183,184, 337,338,414, and you can find something else.
bogdanfirst
just acts like an inverter, ha.
by t
wovk
anyone can explain me how this circuit work? I know that for a PNP conduct, the base current must negative (voltage Vbe too), I mean the base current must goes in the Output of the 555 timer... this is what I don't understand....
the pnp base voltage is fix to 7V (approx.) (drop voltage from diode) right?
so if my logic is good the Infrared Leds will be ON when the Output of the 555 (pin 3) will be low?!?! :?: :?:
kinjalgp
Active Member
Yes you are right. For a PNP to go into conduction, the base current should flow out of the transistor and should be grounded some how. So when 555's output is low that means its output is connected to ground internally which in-turn pulls the base of PNP to ground thereby causing a current flow which flows out of its base and turns it on. :)
kinjalgp
Active Member
Just remember that to turn on a PNP its base current has to flow out of it and for NPN the base current flows into it.
wovk
correction:
... and for NPN (Not Pin iN :) the base current flows into it.[/quote]
Pilot
David,
You took out the BC557 but what did you do with the 180R resistor and the 1N4148 diodes?
If you just connected everything together in place of the BC557 then all you will do is put 7.6 volts through the leds without the benefit of a current limiting resistor.
Can you post an amended diagram
Wait untill you have an electrolytic capacitor in an oscilloscope psu explode - then you know the meaning of ***BANG***
Have Fun experimenting.
:lol:
daviddoria
you are correct... i just connected everything that was going through the transistor together. so i threw 7v at 2 LEDs.... so why is that bad? shouldn't they have like a 12v max? was that the purpose of the transistor, simply a voltage limiter?
thanks man
david
bogdanfirst
no,no no!!
Ir leds operate on low voltage, 1.*to 2.* vokts, so without hte limiter you cant do anything, cause you will burn the leds
