Hi gang.
My first post so apologies if I mess it up.
I've got an application where I need to send a short pulse to a dc latching solenoid valve to open it and close it. The trigger will come from a vacuum gauge with an adjustable "trigger" that closes a circuit like an on/off switch at a user selectable vacuum level. The pulse needs to be only 6 - 12 volts for 10 milliseconds at 5 watts so not much power needed for that (I realize that I may need to go through a relay). The problem is that this device will be in areas where no power is available so it needs to be battery operated.
In reviewing various circuits it seems that a low power version of the 555 chip in monostable mode with edge triggering is the way to go but it seems to me that the edge trigger method (because of the resister needed) will likely consume too much power and there will be a need to replace the battery much more frequently. Does anyone have any ideas on how to trigger the 555 in another way using an on/off switch as described?
Since this switch needs to operate only once every two to five days and it will be outside, I was thinking that maybe using a very small solar cell to charge a capacitor which would be triggered when the switch is closed to trigger the 555 but I'm not sure how to design such a circuit. Any thoughts would be appreciated. Thanks.
