eagle to orcad
prandy
hey....i am doing a project involving nokia 3310 lcd...am only a hobbyist so cant work with smd components, thats why i wanted to make a breakout board for the lcd...the problem is the breakout board is in eagle but the pcb fabricator uses orcad...so can someone help me to convert it from eagle to orcad :(
Can't you output gerber files from eagle and import them with orcad? They have to share at least 1 common file format.
Why not get a laser printout to a tracing paper & give to the pcb fabricator ?
BTW I had the same issue here.Pcb fabricator is using orcad & I'm using Eagle & Sprint.
Doesn't the pcb fabricator accept PDF format?Same here he is very scared to take PDFs.
actually i am very new to eagle....yeah he doesn't accept pdf's :(....actually a breakout board for the lcd designed in orcad will also do... :)
