Hello everyone!
In the last couple of days I've been designing a really simple circuit just to amp something up (lets call it AMP). To do that I'm using op amps. The ideal would be to supply them with +-4.5V, but since I only have a 9v supply, I'm just biasing them at 4.5v and then using a high pass on the exit.
But here comes the problem, I have another circuit monitoring the output of this previous (lets call it MONITOR). The MONITOR loads the AMP in a way that the output gains a DC level, neglecting the presence of the high pass.
After a few tries I noticed that if I further filtered the input of the MONITOR this offset would go away. Another problem is that I need -40dB at 0Hz and near -1dB at 15Hz. A second order filter would give me these specifications, but a double RC filter doesn't seem to be working. I tried a Sallen-Key and it worked wonders, the thing is, I don't have the negative supply to power it in real life.
tl;dr: Only have a single supply to bias amps, need to filter output with -40dB/dec. Can't use active filters, double RC is not working.
Can you guys help me out? I'm new to designing circuits, it has always been "assemble this and it does that" kind of thing.
Thank's in advanced!
EDIT: The monitor circuit is really sensitive to DC levels since it contains a rectifier.
