DS1307 interfacing with pic 16f877a
rcsnair
I am facing a problem with ds1307. I made a cirucuit to display date and time on 16x2 lcd display using pic16f877a. Its working perfectly well but when power supply goes, ds1307 is not keeping its time, I connected 3V battery to ds1307 as per its datasheet. Can any body help me regarding this problem.
A
amando96
Guest
Lets see the code.
The first code you insert into the PIC, tell the ds1307 to start off with say 12 hours and 10 minutes
every time you put that code in, you start from 12 hours and 10 minutes, you have to put that code ONLY ONCE, and then remove the part that tells it to start from that date, leave the battery wired to it at all times.
After you turn it off, what do you get? just zeros?
rcsnair
Circuit for my project
The circuit is as shown in the following link
Digital Clock using PIC16F877A and DS1307 RTC Code in MikroC |Linux and Microcontroller Tips
I am using the crystal 32.768KHz
Thank you,
ericgibbs
Most Helpful Member
Hi
Looking at your link, that shows a DS1307 with no battery.?? pin3 at 0v
Perhaps the program is written assuming the power is never switched off the project.??
Thank you,
Hi
ie: it re-inits the DS1307
EDIT:
Unable to get the program from that link.?
The d/s for the DS1307 says pull up resistors, not pull down, I use 2k2 pull ups, no problems.
