konradIC13
Hello,
Im making an electronic circuit. Its purpose is to switch on 5V DC fan when both of my switches are on and turn off the led when both of my swithes are off.
The circuit is powered from Li-po 7.4v battery pack (voltage range 6.3v nearly discharged and max 8.4v fully charged). Then the voltage is stabilised at 5V by 7805IC.
Two SPDT switches and 4011IC are preventing connector bouncing and they distribute low/hi signal to logic 4081 and 4071 devices.
Next the 4081IC is responsible for turning on fan. I have read somewhere that the 4081 output signal is too weak to turn on MOSFET transistor so i put a BC548 transistor there and the nthe BC548 transistor is driving an n-MOSFET IRF710 transistor which turns on the 5V fan (fan max current is around 1A)
The other 4071IC is driving 2n2222 transistor which is responsible to turn on and off Blue LED (3V voltage drop, 22mA current).
So far i have only simulated the circuit in my PC but before ill try to do anything 'in real' i would be gratefully if someone with bigger experience could verify my schematic and check if i have correctly attached transistors if i didnt missed anything. Im not sure if they transistors are right ones and if they will function properly (if the voltages/currents will be enough to turn them on and not big enough to melt everything). Also are the capacitors values good enough for 7085 stabiliser (i took them from example uses from is datasheet)?
Thank you very much for any help in advance.
ps. i also heard that IRF3711 transistors could be useful here and would be able to turn on the fan when attached directly to the DC4xxx output an they can power a fan with 1A current. Is it true?
