Hi
I am trying to find out how to drive an N channel Mosfet on the high side of a H bridge. The H Bridge drives a stepper motor.
I understand in order to drive the N mosfet in reverse the Gate voltage must be between 4 to 7 V higher than the Supply Voltage. Say the motor voltage is 20 V then the gate voltage must be 24-27 V???? If so, does the gate current also increase compared to driving the N mosfet on the lower side?
If the rest of the board has an additional 12 V and 5V supply for the logic, why can you not only add these to the motor supply voltage and thus obtain the gate drive voltage of +-25V? Why doe you require a charge pump or voltage doubler if this is possible? If this is possible, how do you protect the logic circuit from any back EMF of the motor.
I am a newbee and any help would be highly appreciated.
