Drill Bits
lclark
What is the best size drill bit for regular hole through components...common resistors, IC sockets, and such? Thanks in advance!
I use mostly .024" (#73) for most parts. If the layout is tight, and a part has really small leads I might go down to 0.018" (#77) but this is a pretty delicate drill. Sometimes a part has larger than normal leads so I keep a few larger drills all the way up to 0.0465" (#56).
Ditto. I drill all my holes with a .024" bit. It is a bit sloppy for fine leads but still works. It is a tight fit for .1 pin headers but they go in. If in need a few larger holes I enlarge them with a bit in a pin vice or exato knife handle.
I always break those little suckers. So my default is #53 drill.
I tend to avoid anything as large as #53 because it's hard to get a good tent of solder between a .020" wire and a 0.059" hole.
On Boards that I used to make & those that I contract out, I used a 0.8mm(31.496mil) hole for most parts (0.6w resistor, caps, 1n4148 etc) & 1mm (39.37mil) for (4004 diodes, 1W zeners etc..)
This always leaves plenty of room for consistent solder wicking to the top side pad.
However there are instances where I will make a hole a tight fit eg: single sided board & mechanically stressed (heavy) part, the close tolerance hole takes the stress away from the solder join.
