DPDT thru-hole PCB DIP switch?
dknguyen
Most Helpful Member
Does anyone have an extra DPDT through-hole PCB mount DIP switch (rocker, lever,toggle, or otherwise). Similar to one of these (but through-hole). I need it to toggle between the data/clock lines of the programming pins and emulator pins on a PIC.
https://www.electro-tech-online.com/custompdfs/2006/09/B-13.pdf
I'll pay you anything! (Well not anything, but I'll pay quite a bit more than it's worth).
It's the only part I need and Digikey nor Mouser doesn't carry it, and I don't want to have to pay massive shipping or handling fees.
Thanks!
I don't have one but, www.farnell.com stock these (may be known as Newark over there). Search grayhill and it comes up. They have a minimum order value of £20 here in the UK for credit cards, but if your work have an account with them, there is no minimum order value.
I have two each of the 78 series they are marked 78G02. All they will cost
is the postage.
Ned
