Hi
We wish to make a 6W Buckboost switch mode lighting PCB (15cm by 1.8cm) with LEDs one side and the driver electronics the other side. (everything SMD) There will also be a microcontroller to give dimming control.
We want the PCB to be as thin as possible, but not so thin it bends easily.
We believe that we can have two pieces of MCPCB which sandwich a plastic core. We will need plated through vias for the tracking of the driver & control electronics. We believe that plated through vias can be achieved with this setup, and can be done by simply drilling though both pieces of MCPCB where the vias occur, and then drilling through the plastic core in the same position…then plating the hole of the plastic core.
Do you believe that this is possible?
How expensive would you think this would be?
Vin = 20 – 50V
V(LEDs) = 45V
Vin = 20 – 50V
V(LEDs) = 45V
