Dont understand electric fence
florida
From what I gather electricity flows through the fence wire and is grounded to the soil. The soil is the return path. Current runs through the soil into a buried galvanized rod and then back up to the power energizer. My question is, "Why doesn’t the soil create resistance?" You would think that dry sandy soil would drop the voltage so much that it would diminish the effect of the shock. Also, is the current constantly flowing through the circuit or only when someone touches it?
I’m using a 120 volt AC 60 HZ with intermittent output
The soil does add resistance. But even dry soil is conductive enough that you'll still get a shock.
Besides leakage due to imperfect insulators, only when someone or some animal touches it.
I hope you are using a proper fencer and NOT directly connected AC line voltage! :eek:
Thanks, Im using the Saco 3 electric fence box. I have a bunch of pvc fence post with holes drilled in them to hold the wire. I dont think that pvc would conduct too much current.
PVC has good dielectric properties. Some PVC doesn't last very long in sunlight due to UV. Make sure the PVC you are using is UV stabilized, which it should be if it was designed to be used as a fence post.
