Dont know what the component is.
RexIR
The component is on a 24Vac to 12Vdc converter circuit on the input side. the circuit also supplies pulse output to stepper motor. Component is
B222M 250VAC
Can anyone help with identifying it? if needed I can post the Pic.
Thanx in advance for the help.
Rex
It's probably a capacitor, 2.2nF.
Thanx Hero,
I already know it is a capacitor. but need details and datasheet. it has a peculiar shape with both leads coming out of 2 spindle like bulge from the capacitor disc.
Any idea?
If you knew then why did you ask?
It's obviously rated to 250VAC what else do you want to know?
The letters normally indicate the tolerance but that isn't important.
sorry for not being specific when i started the thread. The issue is I am not able to find the maker or the datasheet for the component. And since it has a shape that I have never come accross ever before I am not sure what it does in the circuit and if its some special kind of capacitor.
You said it was a 24VAC to 12VDC converter, are you sure you don't mean 240VAC to 12VDC converter?
The only special thing about the capacitor is that it'll be designed to be connected across the mains, so will be X-rated, no nothing to do with p0rn :D, it's an overvoltage rating.
