Does anyone knows about PC?
bmb99a
My PC's media player and Winamp and windows's other sound's are too fast playing. I have tryed to doing partitioning and formatted, then installed windows again.
I have tryed to install drivers for my soundcard. But it still.
Does anyone knows what should I do?
More info about your sound card, motherboard and windows version would have helped.
Perhaps you have the wrong sound card driver. If it is a sound card built-in to the motherboard, then you need to check it on the manufacturers web site as they sometimes have several possible drivers depending on the exact motherboard revision.
You don't say what version of windows you are using, perhaps you need to install servicepacks which may fix problems if using the default Microsoft drivers.
Get the latest drivers from the sound card manufacturer and if all that does not work, try with a different sound card.
Fast sound
That's definitely not a problem of the sound card or the driver. It is an OS problem. Check out in the device manager what speed settings are used. Check 'normal' if it is set 'high'.
It must be using Realtech HD audio. on the task bar there will be a button for it. right click and open. Otherwise you may go thro' Control panel also.
On the right side you find a button called Karoke
it has clickable bttons Up and DOWN and a counter reading its value. this must be showing "one or "2" in your case.
Set it to "ZERO"
Click OK and come out. now you try playing a song / music.
everything will be OK
Thanks a lot. How can I check out in the device manager what speed settings are used? I can't find the speed settings.
Set it to "ZERO"
Thanks a lot. Do you have Realtech HD audio? If so, please send to me. Thanks.
Thanks a lot. I will try.
Realtech HD audio driver is not something to be ziped and sent.
this package is bundled along with motherboard drivers. Inmy case i use Intel915GVRS mother board and under winXP.
if the Karoke is set at 1 or 2 the sound appears as if playing at faster rate- but play time is same. the voice becomes shrill
similarly if it is set at -1, or -2, the voice appears more base than normal.
Again play time is not changed actually
Please see if you use similar motherboard you may try out.
However any motherboard audio driver, now a days provides for Karoke function. you can sort out the issue by a check of yo audio driver in the control panel,and tuning the Karoke properly.
