OneOfDaZZZ
So I have been searching the web and Power of Eithernet is starting to become cheap for 1 port injectors however 4-12 port units are still kind of expensive and really there isn't much to them. I need a rig that can handle supplying 802.3af standard POE voltage(minimum 44 V DC and 350 mA) I've looked online for 48 volt circuit designs but most 48 volt designs seem to be centered around audio amps and they tend to want a higher current then i need for this application.
FYI -
using to power cheap POE CCTV cameras
input voltage could be either 100VAC +/- 10%
If anyone has already done this and wouldn't mind sharing I could use the help.
OneOfDaZZZ
FYI -
OneOfDaZZZ
