I've recently seen some great videos on YouTube made using a DIY Video Camera slider system for around £10. The idea is that the video camera can be manually pulled slowly along a set of rails alongside what you are filming, achieving a beautifully smooth tracking shot.
I'm building my own version of this, which has a camera mounted to a device similar to a roller-skate. The advantage of this, is that the axels can be adjusted independently, to allow it to curve for other shots if I wish. With the wheels straight, it will be pulled down a piece of plastic trunking or square drainpipe cut in half alongside the things I'll be filming.
The £10 versions on YouTube have you pull the camera down the track manually, which is quite smooth, but I want it smoother than that, and I also want more control over speed so I can do a really fast shot from left to right if I want to.
So I'm looking to put a motor on the end which will pull the roller-skate (Weight is 1.5KG with camera mounted on top). I also need some sort of speed control, and it must be battery powered.
The though had crossed my mind to pull a toy car apart, but I'd like to learn how to do it.
So I'm looking for ideas on power, a motor big enough to pull the camera along the rail, and potentiometer or speed controller system. Control at slow speeds are a main priority.
I've mocked up a diagram and look forward to any help you guys can give.
Cheers
Kristian
