Displaying decimal points on LCD
drkidd22
Hello,
I have the following code, it works fine, the only other thing I want it to do is display decimal point to the LCD. It simply reads some voltage on a analog pin and displays it on the screen, it work fine for single digit only as it is. Any help will be appreciated.
void Voltage (void)
char line[16];
int Vref = 5000.0;  //Converts reading from ADC to mV
double ADCBubbleV, BubbleV;
int bADCVal, BubbleVi;
SetChanADC(ADC_CH6);
XLCDDelay4ms ();
ConvertADC(); // Start conversion
while( BusyADC() ); // Wait for completion
XLCDDelay4ms ();
bADCVal = ReadADC(); // Read ADC
ADCBubbleV = ((bADCVal/1024.0) * Vref);
XLCDDelay4ms ();
BubbleV = ((ADCBubbleV)/(204.0));
XLCDDelay4ms ();
XLCDL2home();
XLCDPutRomString("Bubble (V): ");
BubbleVi = (int)BubbleV;
sprintf(line,"%d",BubbleVi);
XLCDPutRamString(line);
XLCDPutRomString("                ");
XLCDDelay4ms ();
This is the way I would do it. There is probably a better subroutine out there though.
int result;
BubbleVi = (int)BubbleV * 100; // 2.34v would change to 234
result = BubbleVi / 100;
XLCDPutRamString('0' + result); // 234/100=2.34 (2 as int)
XLCDPutRamString('.'); // Decimal point
result = (BubbleVi / 10) % 10;
XLCDPutRamString('0' + result); // 234/10=23.4
                                              //  23.4 mod 10 = 3.4 (3 as int)
result = BubbleVi % 10;
XLCDPutRamString('0' + result); // 234 mod 10 = 4
i think that it depends uppon the variable kind that you've assigned, if it is float or long , then it will be displyed with the decimal point,
this is my view!! hopefully correct
