Hello,
I am building some custom Solar Panels using 3x6inch cells rated at 3.5A 0.5v (1.8watt)
I need help selecting 2x diodes for my panels.
I can easily get the normal rectifier diodes 6A that is rated with 0.95 F voltage drop 1000v
better diodes have drops of .55 is it worth it?? only .4v
I am thinking of using a Schottky type diode because they have low forward drop.
SR504 SB540 5A 40v diode is it ok to use. (0.55v F drop)
1. I will be using 4 strings of 9 cells for a total of 36 cells giving out 18v @ 3.5A (60watts)
I will be putting 4 of these 60watt panels in series for a output voltage of 48v nominal.
I don't understand how the panels being in series would effect the diode.
40v, will be fine because it is only handle 1 panel? or the panels having a high voltage maybe about 60-80v open circuit voltage.
does this example have truth? say 3 panels with open voltage of 60v 4th panel would have 60volt going thou it? so i would require a larger diode?
2. my other panel will be 18 cells @ 7A 4.5v to push my MPPT a little higher. this will be used for my current 2x 120Watt Sharp panels. each rated at 7A 18v (20-21 open v.)
it will be a 120(7A18V)+120(7A18V)+32watt(7A4.5V)
if someone can kindly tell me how to install the diode, i'd also applicate that (I currently think on the Positive side, with the diode's stripe facing the away from the Panel. (towards the connector)
with a Professional Solar Panel have a maximum rated system voltage of 1000v, the diode is what limited them?
Thankyou
Shaun
Thankyou
Shaun
