home4sale2
Hi, new member, hope you guys can help. I have a Fahrenheat baseboard heater (LFP1652E) and I need to replace its diodge bridge. The numbers on the DB are SB254 and further search revealed that it might be 25A and 400 Volts (thus 254?). If I order it from a local store it's $40 but on other sites I can see it for $5 or less (rated at 25A and 400V). They look similar (physical size and pins) but the parts are 2504 or different numbers so I can't really cross reference. Questions:
1. Can I use a higher rated DB, I would think so but want to be sure (ex. can I use one rated at 50A and 1000V)? Does it give me additional protection against surges for ex?
2. Are there other specs that I should be looking for (beyond amps and volts)? I want to make sure I am comparing apples to apples and not cause a fire.
Thanks in advance.
Thanks in advance.
