Hi, I would appreciate if you guys could assist me in answering these Multiple-Choice questions :
1) Which of the following statement about BINARY BASEBAND MATCH FILTER is FALSE?
(a) The match filter receiver can be implemented using an Integrate-and-Dump correlation receiver.
(b) In a match filter receiver, the bit error probability is not affected by the input data rate.
(c) The impulse response of a match filter is related to the input pulses.
(d) The match filter is designed to achieve minimum probability of error.
2) The result of f(t)*d(t-t1) where * denotes convolution is :
(a) f(t)
(b) f(t).d(t)
(c) d(t)
(d) f(t-t1)
3) In the digital communication systems, which of the following functional elements is not used to combat the degrading effects of the channel on the signal and maximise the information rate and accuracy?
(a) Channel encoder
(b) Modulator
(c) Transducer
(d) Source decoder
4) Which of the following statement is FALSE?
(a) Impulse sampling is impractical
(b) Natural sampling is carried out using a sample-and hold circuit
(c) Practical sampling pulses have finite duration
(d) Aperture distortion occurs during flat-top sampling
5) Matched filter is used in
(a) Receiver
(b) Transmitter
(c) Modulator
(d) All of the above
(a) f(t)
(b) f(t).d(t)
(c) d(t)
(d) f(t-t1)
(a) Channel encoder
(b) Modulator
(c) Transducer
(d) Source decoder
(a) Receiver
(b) Transmitter
(c) Modulator
