difference between vlsi,ssi and msi techniqes
Parth86
hello
engineer design ICs
small scale integrations-logic gates
medium scale integrations-encoder,multiplexer
vary large scale integrations-memory,processor
can i use vlsi techniques to design gates ,encoder single Ics
Sure. The general idea is that the density of the components has increased. SSI may have used photolithography whereas the higher density of transistors are using x-ray lithography. At one point there were issues about gamma rays from the ceramic encapsulent which had a greater effect when the circuit density increased. The materials had to be better. The clean room better.
Now what has happened in general, is a migration to BGA packages where the leads are non-existant, so even a 16 pin BGA will require a multilayer board to lay out. Muti-layer is greater than 4. It may need 8 layers or more. I've seen references to 40 layer boards.
Learn to program an FPGA, and you can design circuits of every complexity - simple gates, multiplexers, even processors.
Of course, if you only want to design digital circuits that consist of a few simple gates, there are easier ways, but these will limit your options when you want to advance to more complex circuits.
