Mishaerachae
Anyone to help me distinguish between Vdc and Vrms confused.
Note: This feature currently requires accessing the site using the built-in Safari browser.
so far I have been picked up that Vrms is the component of a rectified ac signal
This question doesn't make sense. I think you are mistaking the average voltage for DC. The average value of a HALF-rectified waveform is 0.318*Vpeak. The average of a full rectified wave is 0.637. The average value of a rectified wave is not the same as DC.Please tell me more. My main source of confusion is exactly that. Please explain why Vdc and Vrms have different values. Vm stands for Vmax or Vpeak
Well you can't compare peak with RMS, there's no relationship between them
True, but the maths starts to get a bit too complicated for me if its any more than a sine wave or a square waveBut many waveforms are not a sinewave. Narrow pulses (drum beats?) have a high peak voltage but a low RMS voltage.
I am a second year electrical Engineering student and so far I have been picked up that Vrms is the component of a rectified ac signal that will deliver the same power as dc. But now I am told that Vdc = 0.318Vm and Vrms =0.707 which is not the same. Confused.
Nigel Goodwin I think said it best, although I disagree with his statement
The rms value of a sine wave is 0.707 x the peak value, that is the relationship.
A couple of errors in that statement:320VAC peak to peak = 230VAC RMS
Should sayVAC peak to peak /square root of 2 = VAC RMS
It should say
325 V PEAK = 230 V RMS
Why do you think so? All europe uses this voltage. (I don´t count UK, since it is very soon to be somewhere in the middle of the atlanticI find it quite annoying that people use 230V in examples, as no one uses that for their mains voltage![]()
