Delay Function
EN0
I'm creating a delay function that offers the capability of having the timing configuration in milli-seconds or seconds. See the code below (C18 compiler):
void delay(int delay, char degree = 'm')
    int cntr;
    if(degree == 'm' || degree == 'M')
        // Our timing configuration is in milli-seconds
        OVF = 0;
        T3CON |= 0x80;      // 16-bit configuration set
        for(cntr = 0; cntr < delay; cntr++)
            // Load TMR3H and TMR3L bytes
            TMR3H = (63536 >> 8) & 0xFF;     // Load TMR3H byte first
            TMR3L = 63536 & 0xFF;        // Load TMR3L byte next
            while(!OVF);     // Wait for timer to complete transaction
            OVF = 0;
    else if(degree == 's' || degree == 'S')
        // Our timing configuration is in seconds
        OVF = 0;
        for(cntr = 0; cntr < (delay * 2); cntr++)
            TMR3H = (64536 >> 8) & 0xFF;     // Load TMR3H byte first
            TMR3L = 64536 & 0xFF;        // Load TMR3L byte next
            OVF = 0;
When I build the program it says that this line gives me a syntax error:
This is presumably due to the "char degree = 'm'", but I'm wondering why that is so? I'm more familiar with PHP, and in that particular language, this makes it easy to assign a default value; if no value is entered in the second parameter when the function is called, it defaults to 'm'.
I'm hoping this is possible somehow in C?
Thanks,
Austin
No its not possible to initialize a variable in the function call in C, (This can be done in C++ by overloading), but if you compare the 's' || 'S' first, you can the default to milliseconds if degree contains anything but 's' or 'S'.
Okay, thanks. I revised my code to have it as a default (else statement), but it adds more lines than one would deem necessary.
void delay(int delay, char degree)
    int cntr;
        OVF = 0;
            OVF = 0;
        OVF = 0;
            OVF = 0;
    else
        // Our timing configuration is in milli-seconds (default)
        OVF = 0;
            OVF = 0;
like this
    int cntr;
        OVF = 0;
            OVF = 0;
    else
        OVF = 0;
            OVF = 0;
Then you don't need to specify milliseconds as this is the default, BUT 's' or 'S' will set seconds
