Decoding a PWM signal
gaspode42
Hi
I am working on a project which requires the decoding of a PWM signal. I believe this can be achieved by looking for rising or falling edges (using CCP & a timer).
Am I correct in thinking that once the timer is running I have to manually poll the port to detect a state change and then stop the timer?
If anybody can advise or point me at a good tutorial/technote about this I would be most gratefull.
Chears
Yup. It's fairly easy to do.
Well... You could do that, but that's a very lame way to do it. Instead, use the CCP1 capture register & interrupt. Makes it very easy to do, and accurate. Polling won't be as accurate, and it takes all your MCU's time to do it. With interrupts you can get other things done while capturing your pulse widths.
If anybody can advise or point me at a good tutorial/technote about this I would be most grateful.
Have a look at **broken link removed** and **broken link removed** on my site. Very simple code that shows how to do exactly what you want to do for PIC 12F683 and 18F1320. Written in BoostC.
