DC signal --> PWM signal
Mobz00
Hi
I got a analog 0-10V signal and I want to convert that into 0-100% (duty cycle) PWM.
ex.
if my input signal is 0V the output 0% (duty cycle)
if my input signal is 5V the output 50% (duty cycle)
if my input signal is 10V the output 100% (duty cycle)
I found this device: https://uk.rs-online.com/web/p/optocouplers/4693167/
but it is expensive and doesn't come with much info..
Does anyone know of a cheap device that can do the same?
In the end I want that PWM signal to control a solid state reply...
You could use this PWM circuit. It has a 0-1V input range so you just need to use a 10:1 resistive attenuator to convert your 0-10V signal to 0-1V.
Design an oscillator using opamps to generate a triangle wave. Feed the output into one half of a comparator. Use the other half as your Vin reference.
That's how some switched mode power supplies do it.
