data sheet for CdS Photoresistor Radio Shack# 276-1657
engr_ali1
I am looking for data sheet of CdS photresistor radio shack # 276-1657. Can anybody help me with this. The data sheet should include rise and fall time and range of λ.
Google is your friend. Search term is simply 276-1657.
Photocells Multipack (5) 276-1657 Specifications says:
Photocells Multi-pack (5)
(276-1657) Specifications Faxback Doc. # 38703
TYPE ILLUMINATION @ RESISTANCE ILLUMINATION @ RESISTANCE
P722-7R: ......... 1 Lux .....@.. 13 kOhms ..... 100 Lux ....@... 900 kOhms
P722-5R: ......... 1 Lux .....@.. 15 kOhms ..... 100 Lux ....@... 1.1 kOhms
P1201: ........... 1 Lux .....@. 120 kOhms ..... 100 Lux ....@..... 7 kOhms
P201D-7R: ........ 1 Lux .....@. 130 kOhms ..... 100 Lux ....@..... 8 kOhms
P201D-5R: ........ 1 Lux .....@. 160 kOhms ..... 100 Lux ....@..... 9 kOhms
CELL RESISTANCE
POWER VOLT.BETWEEN 10 LX RESPONSE TIME
TYPE DISSIPATION TERMINALS 0 LX MIN~MAX RISE DECAY
P722-7R: .. 150 mW ... 200 VDC . 0.5 MOhms . 2.5~7.5 kOhms .. 50 ms . 40 ms
P722-5R: ... 70 mW ... 100 VDC . 0.5 MOhms . 5.3~15 kOhms ... 50 ms . 40 ms
P1201: ..... 70 mW ... 100 VDC ... 5 MOhms .. 20~60 kOhms ... 40 ms . 30 ms
P201D-7R: . 100 mW ... 200 VDC .. 20 MOhms .. 23~67 kOhms ... 50 ms . 20 ms
P201D-5R: .. 50 mW ... 100 VDC .. 20 MOhms .. 48~140 kOhms .. 50 ms . 20 ms
Coating: ...................................................... Resin (All)
Voltage betwee Terminals @ 25 degrees C............................ 100 Vdc
Power Dissipation @ 25 degrees C..................................... 70 mW
Ambient Temperation Range (C).................................... -30 - +80
Spectral Peak............................................... 540 nm typical
Cell Resistance 0 1x....................................... 5 M Ohm minimum
Cell Resistance 10 1x.............................. Min 20 kOhms - 60 kOhms
Gamma 100/10.................................................. 0.75 typical
Pre-historic Error (Change PE) @ 1 1x............. +0.10 for 30 sec typical
Pre-historic Error (Change PE) @ 1 1x............ +0.15 for 120 sec typical
Color Temperature Error (Change CE @ 10 1x).................. -0.15 typical
Response Time @ 10 1x................................... 40 ms Rise typical
Response Time @ 10 1x.................................. 30 ms Decay typical
Specifications are typical; individual units might vary. Specifications are
subject to change and improvement without notice.
(EB/km-5/6/97)
Please do not make duplicate posts or threads, they do not increase your chance of a helpful response but only reduce it, as people get confused and can't always see what others have suggested in the other thread(s).
If you have made this post or thread in error then please do not be offended. We get lots of people making duplicate threads under the misapprehension that it will increase their chance of a helpful response when in practice the reverse is true.
https://www.electro-tech-online.com/threads/data-sheet-for-cds-photoresistor.85780/
