Hi
I want to drive a gigvac relay with rely current 75 m amp from DSP output pin . I am confused between two options.
The first option is using a mosfet to drive it. But the problem is that the DSP output unlike to pic micro is 3.3 v which is not enough to directly drive the mosfet. I can add another stage using bjt to drive the mosfet. I do not feel good adding a new stage because if I am adding one more bjt to drive the mosfet I need to add resistive division to supply the bjt with 12 volts (actually I do not have 12 volt line on my board and the gigavac relay works with 24 volts) .
I started looking for very low Vgs(th) power mosfet then I may be able to use only mosfet being drived directly form 3.3 volt of DSP pin . Something like IRL510SPBF-ND which has Vgs(max)=2 volt. But I am not sure if 3.3. is high enough to perform well on the mosfet even with 2 volt Vgs(th).
So what do you think about using a darlington to drive the relay without any need for mosfet and another bjt. I got he feeling that mosfet are much more popular than darlingon for drive. i know they are more lossy. But is it the only downside or there are more disadvantages that I am not aware of ?
Any comment?
Any comment?
