Hi!
I am a electronice newbie and i have tried repairing an amp... one of the main ICs was damaged and the output level-meter of that channel was damaged so i bought 2 new such ICs, soldered them in and switched it on... everything was fine until suddenly (i was just turning the volume up a bit) the channel which was damaged before went off and smoke came out of that IC... then also the power supply died for some reason but the transformator was not hot at all and it didn't smell at all!
now when i plug the amp in there's about +/- 120V AC coming out of the transformator, but it's the same signal on both outputs (altough the unit is not powered on! there are some big ceramic (?) capacitors at the on/off switch - could some voltage go through these into and through the transformator?)
wether i set the power switch to on or off - there's about 120V AC like everywhere in the amplifier (GND, signals, ...) and nothing changes when switching the power switch...
Unfortunately i do not have a multimeter to measure the current going into and out of the transformator (if that would help...)
Like i said i am a newbie. Does anyone have any ideas what could be wrong?
Btw: the transformator is inside a metal case and there's glue around it so maybe it burnt through and i didn't notice it? but it didn't get hot... hrm :roll:
Thanks,
blight
Thanks,
blight
