DirtyLude
I've got 3 different model chips now that all use JTAG for programming/debugging and the 20pin connector is huge for the tiny boards that I create.
I'd like to standardize on an 8pin JTAG connector, and since this is a custom connection only used on my boards, I can use any 8pin connector I want.
The requirements are:
- It needs to be able to be connected/disconnected multiple times.
- It needs to be as small as possible and still remain usable.
- keyed.
- 8 connections. It doesn't matter if they are inline or multiple rows... They are signal connections. No power needed.
- it needs to be cheap. Trying to remain under $1 for the board connector, but if they are really small/rugged/SMD, I could go higher.
- SMD is preferred, but not required. I have no problem with 0.5mm pitch.
- direct connect to a flat cable would be nice, but also not required.
I've done some searching on Digikey. I found some 2mm headers that look nice. I originally thought Flat Flex would be optimal, but I'm concerned that they have problems with multiple connects/disconnect, plus they seem to be really expensive for some reason.
- keyed.
