Hello,
The following shows how a current mirror can be used to equalise led string currents....
https://ledlight.osram-os.com/wp-co...rentDistributioninParallelLEDStrings.Web_.pdf
..it obviously works on the principle that matched BJTs with equal Vbe's, will have equal Ic's.
However, if greater string current flows in the led string which contains the "reference BJT", then the current mirror doesn't work.
....is this because in such a case, the "non-reference BJT's" would always have at least as much Collector-emitter impedance as the "reference BJT"?
