Hi All,
I am working on a project that will run an alternator to generate a charging voltage for a battery bank. I will be controlling the speed of the alternator to get my desired charge voltage (after the rectifier).
The charge voltage from the alternator/rectifier is fed to a battery bank via a FET switch so I can connect/disconnect with my microcontroller. The battery bank has a current shunt in series with the ground so I can measure the charge current in the bank.
My question is can I PWM the FET to control the amount of current? It seems by doing so, ultimately I would only be affecting the voltage (and the current by law)
What is the most effective way to control the current of this circuit? I would like between 2-4A and the charge voltages can range from 14V-55V depending on the battery config. So wattage from about 56-220W.
I am assuming simple resistor limiting will be super power hungry.
Thanks!!
Thanks!!
