Hi!
Another of my cordless tools has hit the point of uneconomical 'repair' - where the cost of the new batteries exceeds a new tool.
This one is a circular saw - so no real need for the battery to be attached...
I find this really annoying, previously I have successfully replaced the batteries (they're often just sub-c NiCds) but this is a bit of a pain.
I'm currently thinking of making a generic battery pack (using new NiCds and the temp sensor from the original pack) and then run a power cord to the tool from the box (!!)
If I have an 18V battery and a 500W tool - I'm going to be drawing around 30Amps, for a 12V battery and 500W this would be 42Amps
(perhaps a (significant) spike more at motor start up)
Car battery jump leads are rated at 200A plus - but I wonder if they could withstand 30Amp for "a few minutes at a time"?
I've done a bit of research and feel that 8 gauge cable should be sufficient (and have some flexibility)
I really want this to be possible as I could then re-use the charger and, if I get a suitably rated female socket, I can fix that to the empty original battery pack thus making it 'look the part'. As other 18V tools die I can just replace their batteries with another connector. Who knows, maybe I'll just buy second hand tools from thereon ;-)
So, could I use some 8 gauge Car battery jump leads - perhaps 1.2m long - to join the battery pack to the tool?
And, if so, are there any reasonably cheap durable connectors I could use? (Andersons are too pricey - even if they are perfect)
