Hi, im currently working on a test rig for a new type of display that our company is developing. Essentially this display (in extreme prototype stage at the moment) is an 8x8 grid of optical dots (ie and 8x8 dot matrix). Each dot is approximately 8mm in diameter, and the same distance between each dot.
The test rig is designed to check each dot to see if it is on, how long it has taken to turn on etc. I therefore need 64 sensors. Obviously the main problem is that a pic doesnt have 64 inputs. My first thought is to do some kind of matrix array using coordinates (x,y), where there are 8 sensors per pin on the PIC, so will only be using 8 pins, but am having difficulty with the actual reality of designing it. Does anyone have any thoughts at all? have a hit a slight brick wall and would appreciate any ideas!
Many thanks,
Ferg
Many thanks,
Ferg
