converting file type?
Thorpydo
Hey,
I have a program written in basic. Can I use MPLAB to convert it to assembly and then MPASM to convert it to hex? If so how? And if not, how would you go about this?
Nigel Goodwin
Super Moderator
Most Helpful Member
Thorpydo said:
Hey,
You require the BASIC compiler the program was written for, this converts the BASIC source either to assembler (which you can then use MPASM on) or directly to a HEX file.
Thorpydo
I origionally programmed it with the Pbasic parallax software as I was using a stamp. Since then I have used Crownhill's "PICbasic" demo software and modified the code so there are no errors. The restriction with the demo version is that it only creates code for the several PICs(non of which I have).
I don't really mind paying for the software but it is not offered in the US and may be able to get by with the demo version.
I now have assembly code for the PIC16F877. Is it a simple task to convert it to run with my PIC16F628?
Thanks!
Nigel Goodwin
Super Moderator
Most Helpful Member
Assembler code for the 16F877 and the 16F628 are identical, they both have the same 14 bit core. The only differences are in the hardware, the 16F628 has comparators and the 16F877 has analogue to digital converters (and lots more!). The only changes you need to make are in the settings of the hardware - unless you are using hardware not available on the 16F628?.
:idea:
Hello, you can program a pic (type supported) with the working code, read it back with a programmer (e.g. picstart) then dissaemble the code..... this isn't a task to take on lightly, dissasembling code can take a LONG time.... especially basic as it's normally pretty bloaty" <-- que mass flaming from "my basic is better/tighter/smaller/sexier etc than asm" brigade :wink:
I hope this helps
Nigel Goodwin
Super Moderator
Most Helpful Member
Disassembling PIC assembler only takes seconds, you load the HEX file into WinPicProg and press the 'Disassemble' button - source code in seconds!.
I understand MPLAB can disassemble HEX files as well, but I never use it.
There's generally no people claiming BASIC is better/faster etc. It's obviously not, but it has it's uses and is far quicker to write - and the speed of compiled PIC BASIC is generally pretty good!.
Thorpydo
I now have everything setup. I'm using USB KIT 128. I can't configure it so that the program looks at the USB port instead of the com ports.
I've downloaded the VCP drivers and placed them in a folder. How doI install them?
EE World Online Articles
Loading
