Converting between PCB design file formats?
Llamarama
Hello everyone, sorry for plauging you with constant questions as of late, but i've hit a bit of a problem.
I have a .MAX OrCAD PCB layout for a double sided board and would like to open it up and mess it around to a single sided board with a few alterations and additions. However I don't own a copy of OrCAD and can't afford to buy it even with the best will in the world. Is it possible to convert this file into an Eagle compatible file, or even ExpressPCB? I'm clutching at straws here and don't really want to have to recreate the PCB from .PDF exports.
I also have access to all of the Gerber files. Can these be translated back into a CAD format? I was always under the impression that though this could be done, it wasn't recommended for most situations, in a similar vein to decompiling hex files?
Thanks for any advice, Mike
LogicSwap does this as a service.
