Cantafford
I have **broken link removed** BLDC(without the ESC) and I want to control it with a PIC18F2431 using my own code.
I made an inverter bridge out of 2 L293D drivers and simulated the application(worked well in simulation). Like this:
Here are the motor specifications(I have the 21.5T):
I suppose 12V would be fine for running this motor at close to top RPM.
However I have a question regarding the sensors:
For my code I'm using the binary information from 3 hall sensors. The BLDC motor has a jack labeled "Sensors" but on that jack there are 6 pins instead of 3. I'm guessing the motor has only 3 sensors and not 6. Or maybe it has 3 but each sensor outputs 2 signals. I could not find that information anywhere. I searched for a datasheet of the motor but to no avail. All I find is some documentation on it's ESC but that's it.
So my question is: has anyone ever tried controlling such a motor(6 pins from sensors output) with a microcontroller. And if so how are the pins usually arranged?
And is there any way to find out which pins represent the output of the sensors without using an oscilloscope?
