Billy Mayo
My Fluke meter 87 Continuity checker mode test voltage is 2.9 volts
My Fluke 70 III Continuity Checker mode test voltage is 2.5 volts
My Craftsman meter Continuity Checker mode test voltage is at 0.443 volts
When a Continuity Test voltage is at 2.9 volts , what advantage does it have , over my Craftmans Continuity test voltage which is at 0.443?
Why would u want a Continuity test voltage at 2.9 volts? or why would u want a continuity test voltage at 0.443? what do they do differently when measuring Continuity on a circuit board?
An LCR meter when measuring Capacitors , test voltage is zero volts in some settings and others settings its 3 volts
Can I hook up an external power supply and set the power supply to the voltage rating of the capacitor and use the LCR meter in parallel to measure the capacitance of the capacitor at the voltage rating using WITH an ext. power supply? or will this damage the LCR meter>?
