I am putting together a scoreboard project and have made some good progress this week. I now have a prototype diy 7 segment display module built and controlled by a TLC5916IN constant current LED driver. I'm really liking this chip. It has 8 channels, all driven with a constant current and controlled with an SPI shift register. Here's the datasheet:
https://www.electro-tech-online.com/custompdfs/2009/09/tlc5916.pdf
The current can be controlled by the resistor they call Rext. I've been able to use the calculations in the datasheet to calculate the proper maximum current drive for my led strings and it all works great!
Now, here's my question and it's a question probably more out of inexperience and/or ignorance than anything.
I want to be able to dim the scoreboard (for night viewing) with just a single pot or switch, perhaps mounted through the enclosure on the side/back. I will have 4 identical 7 segment displays for the tens and ones digits of both home and away scores, each being controlled by their own TLC5916. Is it possible to use one resistor/pot to control the brightness of all four displays?
Once I figure this out, then the next question is can I use the same strategy to dim all of the TLC5916 driven displays on the scoreboard (there are currently 7 planned)?
Thanks for your input!
