connecting DS1307 to pic
amindzo
i have connected DS1307 to pic16F873A. for reading and writing numbers to DS1307 , the numbers should be in hex mode.
so when i want to adjast the time with keyboard,first i put the nunmber for example 55 in a variable .
after that i write this number in DS1307 but it write to DS1307 in dec mode.
what should i do?
could you help me?
i use micro code studio picbasic pro2.41
i use i2cread and i2cwrite instructions.
this is my program:
note that i can put "$" sign befor number 55 in minute variable but imagine that i enter this number by keboard and it's
decimal. i try on this instruction but it's wrong:
I2CWRITE SDA,SCL,$D0,$00,[$sec,$minute,$hour,$2,$6,$7,$4,$90]
because i can't put $ sign befor variables.
something i should do with the instruction, but i don't know what should i do.
please help me?!
program:
define OSC 4
include"modedefs.bas"
' Set LCD Data port
DEFINE LCD_DREG PORTC
' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_DBIT 4
' Set LCD Register Select port
DEFINE LCD_RSREG PORTC
' Set LCD Register Select bit
DEFINE LCD_RSBIT 1
' Set LCD Enable port
DEFINE LCD_EREG PORTC
' Set LCD Enable bit
DEFINE LCD_EBIT 0
' Set LCD bus size (4 or 8 bits)
DEFINE LCD_BITS 4
' Set number of lines on LCD
DEFINE LCD_LINES 2
ADCON1=7
pause 100
sec var byte
minute var byte
hour var byte
sec=0
minute=55
hour=$15
SDA var PORTA.0
SCL var PORTA.1
DB0 var byte[8]
CMCON = %00000111 ' Comparators = off
pause 1000
gosub write_1307
read_1307:
' Read time Secs,Mins,Hours,Day,Date,Month,Year,Control
I2CREAD SDA,SCL,$D1,$00,[STR DB0\8] ' Read 8 bytes from DS1307
lcdout $fe,1,"Time=",hex2 DB0[2],":",hex2 DB0[1],":",hex2 DB0[0]
'lcdout $fe,$c0,"Date=",hex2 DB0[3],"-",hex2 DB0[5],"-",hex2 DB0[6]
pause 2000
goto read_1307
end
Write_1307:
' Set time & date to 15:55:00 Tuesday 6th of July 2004
I2CWRITE SDA,SCL,$D0,$00,[sec,minute,hour,$2,$6,$7,$4,$90] ' Write to DS1307
pause 10
RETURN ' Sec Min Hr Day D M Y Control
