convoluted
Hello. I'm trying to devise a clever method to power a PC without draining the main car battery when the car is off. The idea is that when the car turns off, the PC will enter sleep mode and discharge only the auxiliary battery. When the car is on, both batteries should be charging. Ideally the auxiliary battery should be a smaller, cheaper battery.
I've originally considered placing relays between the two batteries, which would be controlled via an automotive microcontroller. My concern is that you cannot mismatch two different types of batteries (including age/discharge rates, etc). Can anyone confirm this? I've also looked into diode and solenoid isolators (article: Battery Isolators). What would be the best way to approach this project? Thanks
