Confused with tube radio
I acquired a fada neutrodyne 175 a battery powered tube set at a flea market and noticed that it has three tuning dials. Got a few questions. How do you tune this set? Whats the easiest way to power this thing? (I know it needs all three voltages a,b,c.) Never worked on battery powered tube radios before so any advice would be appreciated.
Thanks in advance -Ray
Nigel Goodwin
Super Moderator
Most Helpful Member
Right, this is probably the schematic (or similar):
And (rather confusing) battery connections here:
Looks like one too many batteries there, giving 135V on the 90V supply.
The extra battery doesn't seem to be for grid bias (if the diagram is correct), but a separate 22V HT supply for the headphone output/detector stage.
It all seems a bit bizarre?, but it's from back in the days before they found the best ways of making radios.
Thanks. Mist of that schematic looks pretty similar to my radio but there is also definitely a c+/c- voltage terminal. (Completely separate from the 22 volt terminal)
unclejed613
Most Helpful Member
It's a TRF set (not a superhet), hence the multiple tuning capacitors - one for each RF stage.
Why three batteries?, usually there's just heater and HT.
"C" battery is for grid bias... "A" for filaments, "B" for plates. those older sets used something like a 3 or 6 volt battery for grid bias, 45 or 90 volts for the plates, and you need to check the tube numbers against a tube chart to get the correct voltage for the filaments. the reason for the grid bias is that in the early tubes, there weren't separate heaters and cathodes like in more modern tubes, so the tubes can't be self biased using cathode resistors, as the filaments ARE the cathodes, and are all wired directly in parallel, with one side of the filament grounded. so a grid bias supply is required to bias the grids properly. the correct term is "dirrectly heated cathode" vs "indirectly heated cathode".
Nigel Goodwin
Super Moderator
Most Helpful Member
Rather confusingly the only circuits I could find show directly heated valves, but with no separate grid bias - but an even more confusing array of batteries, which don't even match the voltages on the circuit? (three 45V in series to give 90V?).
Grid bias is still common on more modern valves, simply to increase the power of the output stages in many guitar and PA amps, avoiding the losses across a cathode resistor.
Dick Cappels
Active Member
90 volts was a popular plate voltage when I was a kid. 90 volt batteries were available all over the place but since the 1960's when I moved over to transistors where would you use a 90 volt battery?
Nigel Goodwin
Super Moderator
Most Helpful Member
Popular over here as well, with portable radios using D series valves specially designed for portable use, with 1.4V heaters.
You can actually buy, or make your own, 90V inverters for running old radios.
Nigel Goodwin
Super Moderator
Most Helpful Member
And radios built with low plate V tubes -
https://www.junkbox.com/electronics/lowvoltagetubes.shtml (Space Charge tubes)
Regards, Dana.
Pretty cool, but falls down on no output valves :(
If you had to use a vibrator for the output stage of your car radio, you may as well use it for the rest as well.
There's quite a few audio preamps etc. these days using high voltage valves with low voltages, just for the fad of a 'valve amplifier'.
danadak
Most Helpful Member
Using space charge power tetrodes at 12V, no vibrator needed, workable. Not boom box
power but still enough to build a radio and get a few mW.:)
danadak
Most Helpful Member
Cars not the only place for radios..... :)
Space charge tubes only designed for cars, no other applications requiring low V
amplification and control pre semiconductor era ? Huh.....
unclejed613
Most Helpful Member
maybe an improvement on the radio Nigel linked, most of the grids in that schematic look like they are operating at zero bias.
debe
Active Member
Here in Australia there was car radios in the early 60s that had 12V valves in the front end & Germanium transistors in the audio stage. They seemed to work well.
