Configuration Bit programming failed.
swapan
Friends,
While programming PIC 16F676 with a programmer (Pic Flash - India made) an error message "Configuration Bit Programming Failed" shows. But if the device is erased and re-programmed, programming successful. In case of a brand new device, the result is same. What I do is first erase the new device (though the device is blank) then program it to have the result successful. The configuration bit is as below. Your comment is solicited.
swapan
__CONFIG _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
Sounds like either a faulty chip, but seeing as you mentioned you tried a brand new device, I would say it was the programmer at fault.
I use the Microchip ICD2 and have never had a problem.
As a cheaper solution I have used the Pickit 2 quite successfully.
Do you have another programmer you can try?
If the configuration bits were at fault I would have imagined that it just wouldn't run correctly, but would still program.
Alternatively, you could, in MPLAB (if this is what you use) set the configuration bits manually to see if that works?
Friends,
swapan
dear swapan
can u post ctk. diagram of Pic Flash programmer - India made with opereating softwaer.
pl post sure
