Condensor mic question
zachtheterrible
Active Member
I've got this mic that has three wires. It says that there is the ground and output (obviously), but another wire says it has optional coupling. I know wut coupling is, but, I don't get it. It also says that it will respond to -5 db @ under 30 hz. Is there such a thing as negative hz?
You can't have a negative frequency.
Condensor microphones often require a power supply - usually 48V for professional ones - your third connection could be power.
Nigel is correct, but the 48VDC is normally used in pro-audio mics.If what You have is just a little button with an small audio cable and a red wire , you can try a 9Vdc battery it should work fine. Radio Shack used to sell them.
